Cyl 3 Misfire after Intake Manifold Repair
I did the flapper valve/intake repair, ran fine immediately after.
Few days later I started getting an intermittent misfire that could be felt, scanner said misfire cyl 3.
I was able to get the misfire to stop almost every time, sometimes by pulling the air cleaner off and playing with the wiring at injector 3, sometimes turning the car off and on, sometimes just on its own.
At some point I also got the fault "Injector Circuit- Cyl 3"
To eliminate the Injector as the problem I swapped injector 1 with injector 3- Since then the car doesn't feel like it's misfiring, but doesn't run super smooth on cold start, is getting poor fuel mileage and still has these faults using a bluetooth generic scanner:
P0203(Hard fault)
P0303(Hard fault)
P0311
P0629
P0641
P2066
I'm wondering if anyone may have experienced something similar, I've obviously screwed something up but the connecter wiring looks fine as far as I could pull back the sheath and everything visually looks fine.
Thanks in advance.
P0203(Hard fault)
P0303(Hard fault)
P0311
P0629
P0641
P2066
Thanks in advance.
Did you replace the injector seals when you did the intake manifold or did you reuse ? Sounds like some wiring is damaged, I would check all the wiring going to injector #3.
Was hoping someone else may have had a similar problem so I could cut down my chase.
