Reducing W204 road/wind noise - the quest to Maybach this car.
Acoustic engineers take excessive care in both isolating the microphone from unwanted vibration and assuring that an omnidirectional (spherical) sonic sample is obtained for ambient acoustic surveys. Harman Kardon engineers spent millions of dollars profiling the interior of the BMW 3 Series and Mercedes C Class with a myriad of measuring instruments, to develop the digital signal processor data for the Logic7 system. The acoustic environment of any car's interior is extremely complex - concert halls and stadiums are simpler.
So have fun on Sunday. Or go for a 50 mph ride in a Maybach, Rolls Royce, or maybe even an EV like the Tesla, Prius or Chevy Bolt. The W204 is far from being "scarily quiet" (it's one of the noisier of 36 cars I have owned) and trying to justify otherwise with ill-gotten numbers serves little purpose. While most MBWorld users talk about making their rides LOUDER, best of success in achieving subjectively "added silence" in a W204. And use the very best measuring device at your disposal - your own ears.
I agree with some of your points, and disagree with some of yours. Of course, HK spent millions on profiling said 3 and C series! -undoubtedly, that's for sure.
The reality is that, and I've said this upthread, the best way for non-professionals like me to figure out noise levels is to use the same measuring device to test multiple cars that drive on the same road at the same speed in the same weather conditions. I don't give any weight to what the DBA is, but the only weight I do consider important info is relative speaking, where does each vehicle lie on the spectrum.
E.g. A C is quieter than a 3 series, but louder than a F150.
Now that said, if I had access to the decimeters that you are referring to, maybe I'd actually give weight to the information given to me. That said, maybe your ears are trained enough to figure out the difference between 67dba and 68dba, but for the vast majority of us plebeians cannot tell the difference, mainly because sound levels, as you know, are not linear. You can also see this all over the web, especially with tire reviews where some people (5%) will complain about tire noise, when 95% think the tire is spookily quiet. Human perception is often poor, and thus for the purposes of my testing, I'll still use some sort of meter, even if the only relevant info it'll give me is relative info.
It would be really awesome if I could even test the same car, driven at the same speed, on the same road in the same weather, with the same brand/make tire, because as we all know, comparing two cars with different tires isn't exactly fair, let alone a car running RFTs and a car without, but unfortunately I'm not inclined to ask a dealer to do this, let alone spend the sum of money to make that happen.
To me, the relevant info gleaned in that Youtube video upthread which can be applied here is that the 7, the S and the A8 are relatively the same, noise wise, provided that the reviewer took 30 second samples of said testing info while measured all on the armrest in the rear, provided he was driving on the same road (at the same speed, which it appears he did). So for me, my next test can be using my car vs an S class, on the same road at the same speed, and these outcomes can be determined.
W204 > S class [and 7 and A8]
or
W204 < S class [and 7 and A8]
or
W204 = S class [and 7 and A8]
because the S, as demonstrated by the reviewer is roughly as noisy as the 7/A8. Agree/disagree?
Also, I think you'd get a kick out of this. https://mbworld.org/forums/c-class-w...5-s-class.html
Compared my W204 (same phone, same app) to a W221 and W222. There are a few variables that I discuss here, but the results were surprising!
http://www.carmag.co.za/technical_po...hicles-tested/
So as I mentioned upthread, it isn't fair comparing my DBA readings with the one in the thread above, but I was surprised to find some further evidence backing up my DBA readings for the S550 in my other thread, here: https://mbworld.org/forums/c-class-w...5-s-class.html
Interestingly enough, the carmag link here showed the S63 at 71dba cruising at 120kmphr. Sure, these results have a bunch of variables to consider, but I found the info interesting nonetheless!
This one is also interesting:
http://elevatingsound.com/the-top-30...-by-auto-bild/
Note though, the only W204 they tested was the BlueEfficiency one, which isn't necessarily a fair test because BE cars have reduced soundproofing in order to save weight. Too bad they didn't test a W204 that was not a BE one! Still, made it to their top 30 list!
https://www.google.ca/url?sa=t&rct=j...DCuQozY8y5FUnd
level @ idle (dB)45.2
@ Full throttle (dB)72.3
@ 70 mph cruise (dB)61.8
versus say a 2011 E https://www.google.ca/url?sa=t&rct=j...DEjXVZHQ7ZWWpE
level @ idle (dB)46.6
@ Full throttle (dB)66.9
@ 70 mph cruise (dB)63.4
This one compares the S to the 7 to the XJ.
http://www.autoexpress.co.uk/bmw/7-s...s-vs-jaguar-xj
Car and driver (2012 C vs BMW etc): https://s3.amazonaws.com/amv-prod-ca...ison-tests.pdf
Car and driver S class https://s3.amazonaws.com/amv-prod-ca...atic2018-1.pdf
Car and driver Lexus LS/Equus (2010) https://s3.amazonaws.com/amv-prod-ca...ndai-equus.pdf
This is basically proof the S class is the same noise level as the W204 at 70mph... surprisingly.
And just for fun: Maybach S600: https://s3.amazonaws.com/amv-prod-ca...chs5602018.pdf
*and holy moses the C450 W205 is noisy! https://s3.amazonaws.com/amv-prod-ca...nuary-2016.pdf
https://s3.amazonaws.com/amv-prod-ca...t-for-38-3.pdf
Interesting. C300 (non DI) W204 at 70mph, 67db. Basically the same result as mine (my vehicle's result was 67db at 120km/hr, which is more than 112kmphr which is 70mph).
Reviewing your posts above, the Jaguar XJ is probably the quietest at about 62 dB (practically useless to try and measure 0.1 dB in a moving vehicle, ones breathing will change the measurement substantially). So using that as a reference, probably the W204 comes in close to 68 dB @ 50 mph and in the 72 - 75 dB range at 70 mph, of course the kind of road surface is the primary culprit of noise, concrete will be 3 - 6 dB noisier than smooth asphalt. Hope you can get trustable measurements.
Interesting
At 50mph
bmw 7 series
50mph = 80km/hr = 66db
mb s class
67 db
Audi a8
68db
The app the guy used gives the same measurements as the one I used (I checked), and while I didn't drive at 50mpn (I will on Sunday), this goes to show our W204s are scarily quiet
Scarily????
Great info there, my car is just sitting right now since my bumper is at a body shop after a long and snowy winter ( Amg sport bumper makes for a nice plow).
Anyways, I found this video;
https://www.deadening.co.uk/pages/advice, this is the main recipe for sound deadening, with all 3 of those combine, you will achieve maybach level out sound proofing. Im going to home depot to pick up some of those rolls and see how much quiter I can get my car, I tested idling again with the windows closed and im at 36-37 DB with the SPL app, will see if the results change after the foam is installed.
Very excited to say I found a spot today that I have confirmed reduces the noise by another 1db! This was my testing methodology.
Controlled environment with a very loud source outside of the car. Test #1 (without my new soundproofing idea/insert). Test #2, -1db or, at best, -another db. (Averaged to 1.5db reduction)!!!!
Same location and same device for the microphone to pick up the sound level. Really excited and can't wait to share. I just have a bit more testing to do tomorrow and then I'll share. A great $20 mod, and LOVING the result thus far
And itwagssf, just reviewing your Youtube video now and will give it a look and see if I can do it. If you can pls post results, I and others I'm sure would love to see the before and after!
I just came back with this, im suprised how light it is,kinda happy about that because I must have over 80lbs already in my car lol. 75 sq feet sure is a lot and Il have enough to double or enough triple layer it in key areas. I plan on starting with the back of the fender splash guards and under the carpets, front and back, including every little exposed metal that mercedes didnt cover up.
By the way, any idea what's a more effective sealer?
Closed cell foam touching a rubber OEM door seal, OR a D type door seal touching a rubber OEM door seal?
I did see this:
https://www.energy.gov/energysaver/w...atherstripping
Obviously, I'm going to be using a closed cell foam due to water concerns, but I'm not sure if I should be using closed cell foam weather stripping or if I should be using D type rubbers only to seal around doors. Thoughts anyone?
I did see this:
Weren't you using some kind of universal rubber stripping? The pictures you showed seemed to be rubber, after seeing those pictures I added this type of foam; (http://www.keepitquiet.co.uk/resilient-sealing-tape/) . I used it in the same spots you did, initially i only had it on the top weather stripping and behind the mirror, theres a triangular shaped rubber seal and I but that foam behind it too push it out and that fixed my wind noise coming from around the mirror.
After seeing you're pictures, I've since put it all around the doors, front and back of the door( next the the fender and back of the door just like you did. now I haven't tested all this, my car has been sitting disassemble for a few days so I can only get Idling results for now.
Now back to the point where people say it is useless, sound proofing has 3 key elements, you need to stop the vibration, absorb the sound and then deflect it, without all 3 you will not see great results. my car already has the vibration part done ( dyno mat), Mercedes does use a lot of foam so that is the absorber and now I will be putting the final touch with the eco roll from home depot with it being the barrier, I'm expecting good results honestly, I have some second skin MLV mats in the trunk which is a barrier like the roll I got but it was 5 times more expensive and I didn't have much of it. This roll I got from home depot isnt as thick but I have so much of it I can just double layer and it will be jsut as good as the expensive second skin mats I imagine.
Now bad to the point where people say it is useless, sound proofing has 3 key elements, you need to stop the vibration, absorb the sound and then deflect it, without all 3 you will not see great results. my car already has the vibration part done ( dyno mat), Mercedes does use a lot of foam so that is the absorber and now I will be putting the final touch with the eco roll from home depot with it the barrier, I'm expecting good results honestly, I have some second skin MLV mats in the trunk which is a barrier like the roll I got but it was 5 times more expensive and I didn't have much of it. This roll I got from home depot isnt as thick but I have so much of it I can jsut double layer and it will be jsut as good as the expensive second skin mats I imagine.
I'm not sure what is better, to be honest. My main thought/concern is for any part that touches metal, is closed cell weatherstripping a good idea? I know closed cell foam doesn't generally let water in, unlike open cell foam, but rubber itself (D ring rubber) holds 0 water since rubber doesn't absorb water.
So from a rust perspective (thinking worst case), I suspect using closed cell foam is not a good idea, because it may still trap some salt and water in the winter, and if that constantly touches a painted surface, maybe it'll rust?
In the pictures where I was putting in foam in the windowsill, well, that was closed cell foam. For my other photos sealing up the doors and such, that's the Amazon stuff above.
I'm just not sure what is better at blocking out sound. Sure, closed cell foam is better at absorbing sound, but I suspect rubber is a better deflector of sound? Too bad I can't use both...well, maybe I can, stick the foam in the rubber seal? Ok, maybe that's going a tad TAD bit too far
**Note, after extensive testing, the closed cell foam I was using wasn't making an effective seal as it wasn't thick enough, hence ditching it and going with the rubber D ring seal instead.
https://www.amazon.ca/gp/product/B06...?ie=UTF8&psc=1
Im looking into the rubber strips and there's many different sizes, which one did you get ? I think im going to order the 12mm.
I'm using the little D one in the Amazon link upthread. It's one cm wide and 8mm high iirc. It's doing a great job right now. Have more on order. Have used about 16 meters, yes meters so far.
So where the hood touches the front fenders on both sides, there's about a 7mm gap. Is it worth sealing that off or is that used for heat dissipation for the engine?
PS - I couldn't find any reference anywhere for either OEM (I doubt it) or aftermarket (surprised that I didn't find any) acoustic glass and/or windshield. That would have been my next move, but I don't see any. Have you or others come across them?
We gotta give these guys a call, a fully armored and bullitt proof mercedes should be really really quiet inside.
Note: My primary goal with this experiment was to ensure that the testing methodology, if followed by someone else, can be reproducible. This was really important to me.
Vehicle tested: 2012 C300 4matic
Tires: Primacy MXM4. 29psi front, 34 psi rear. Please note: on my vehicle, I hear 0 road noise, 0 tire noise. Most of the noise generated by my vehicle that is audible to me is wind noise.
Road: Highway 407, far west end of the 407 to Highway 403 exit. Asphalt only. Those of you who live in Ontario know most of the 407 is concrete and noisy, I ensured that testing was done on asphalt as most of the 400 series highways are asphalt, and on the 407, there are very few expansion joints and fillers in the road, so testing was consistent.
Weather: Between 0-8'C, dry, sunny
Results: ALL measurements taken below: For each run, I focused on getting the lowest DB possible. This usually meant the road was either level or a slight decline causing the engine to work less hard. EVERY single measurement below was taken after multiple attempts to get the lowest DB number possible. I experimented with how best to capture the sound - phone free hand near the center to try and minimize effects by expansion joints, or mounted to a mount. The latter turned out to be more predictable, so all measurements below are captured when the phone is in a mounted position, and the same position every single time. While this does not completely isolate the phone from road noise, etc, it's a pretty accurate measurement as all measurements were taken at the same location.
Control (stock):
60kmph: 60db
80kmph: 62-63db
112 kmph/90mph: 67db
120 kmph: 67db
130 kmph: 70db
140 kmph: 71db
150 km/hr: 72db
Results after modification:
60: 58db
80: 61db
112 kmph/70mph: 66-67db
120 kmph: 67-68 db
130 kmph: 68-69db
140 kmph: 71db
150 km/hr: 72/72/71db
General observations:Success was mixed. Generally speaking, below 140km/hr, there is a noticeable (by ear) difference that is corroborated by decimeter findings. It seems that as one drives faster and faster that there is diminishing returns. Eg There must be so much wind noise/friction generated by the vehicular movement that the db improvements become less and less. That said, qualitatively it would appear that when there is significant cross wind (e.g. a gust of wind) that the vehicle, post modification, is quieter. That said, there is an improvement at speeds <=130km/hr.
Conclusion: For the $40 or so worth of rubber seals I bought, it was totally worth it. This experiment was also really fun to do.
Next steps: I'll be visiting my MB dealership shortly (appointment got pushed out). I will be taking a CLA250 (loaner) and a S450/560 (test drive) on the same piece of road and taking measurements again. It'll be interesting what I find, db wise, in those other cars. I don't think I have any immediate plans to continue my project on my car, but will be looking at the results that ltwargssf as he/she is working on combating road noise/tire noise. That concludes my part of the test
What I find most interesting is that the S550s and such, when testing by Car and Driver, only show results up to 70mph. I think it'll be up to me/us to test these vehicles near the 150kmhr range...
Happy testing and please share your results and ideas!
W204: http://www.thetruthaboutcars.com/2009/02/the-art-ofnoise/ <--very neat. This result is basically giving me the same info as above. 68db at 130km/hr, and since it's already one of the quietest cars in that list, I think I'm done my project... lol.
