Side Marker Bulbs Question
Old Mar 6, 2018 | 01:29 PM
amoffitt's Avatar
C350
Hey guys,
One of the lights in the eyebrow of my passenger side headlight burned out and is needing replacement. Is the part number 000000-008155 the correct one for this? The reason why I ask is because I thought I always ordered bulbs that the part number started with 204-XXX.
Also, does this bulb work as well in the tail lights for the ones that are Side Marker Bulbs back there?
Thanks in advance.
Old Mar 6, 2018 | 03:40 PM
xsever's Avatar
2012 C300 4MATIC Sport
Originally Posted by amoffitt
Hey guys,
It is correct as can be seen here under the Fitment tab.
https://www.fcpeuro.com/products/mer...-000000-006370
Old Mar 7, 2018 | 11:22 AM
nelson g's Avatar
C300 4matic
Check out this site the bulb is a little less
https://store.candlepower.com/w5wblue.html
Old Mar 8, 2018 | 12:08 AM
IGB's Avatar
IGB
'08 C300 MM Pano
The part numbers that start with 204 are those that are exclusively made for the W204 models. However, there are many times when a part is designed and sourced to fit more than one model in which case, the criteria you described would not apply.
