How do I fix my car with Inoperative. See Operation Manual code on dashboard
P 0524; 1303 2091 2095 0946
1351 0942 0155
The mechanical technician said the non-release of the gear and not pumping fuel meant that the “Brain box” was spoilt. I assume that is the ECU. He replaced with another ECU and that cranked and started the car then drove it around up to 1 mile, Putting ECU back still didn’t start the car or open the ignition.
He advised that I change the brain box (ECU). I recall that 4 months ago, at 97K miles the car had an electronic steering lock which cost me so much to fix. Please what should I do, as I have a short while to respond to this suggestion. Your suggestion will be appreciated. Thanks
