ML350 Loss power while driving
Old Apr 4, 2018 | 04:35 PM
rcrespo13's Avatar
ML350
While driving the power goes completely off and the check engine light goes on blinking the power, if I release the pedal the light goes off and the power will be good again.
I check for codes and there is no code stored, I did the service including changing the 2 engine filter and change the Mass Air Flow Sensor and is a lot of more power, but still does it again.
Please help!
Roberto
Old Apr 4, 2018 | 04:40 PM
bowenxue98's Avatar
2014 Mercedes C350 Coupe
Please help!
Roberto
Wrong section. Post in the ML350 section.
Old Apr 4, 2018 | 05:58 PM
W204Motorsports's Avatar
2008 C350 Sport 4Matic Swap
Hi Roberto, you need to connect your scanner and drive around with it plugged in so it shows you in real time.
