Amplifier c300 2012
Old Apr 5, 2018 | 08:50 PM
Bluemonc's Avatar
C300 2012. Ml350 2010
Amplifier c300 2012
My amlifier is failing. Where is the location of the amplifier. ?
Old Apr 5, 2018 | 09:01 PM
bowenxue98's Avatar
2014 Mercedes C350 Coupe
It should be in the trunk behind the tailights.
Old Apr 5, 2018 | 09:08 PM
Bluemonc's Avatar
Amplifier
left side.
I pulled the three fuses and had amplifier reboot
26 67 84.
Then audio worked for a while.
Noe it shows my sat radio is device unavailable
am fm and disk players show to be working but no sound. Therefore must be a failed amplifier.
What do you think?
Old Apr 6, 2018 | 02:06 PM
bowenxue98's Avatar
Well judging by that it would be the amplifier. Although I would recommend you taking it into either a dealer or indy mechanic just to make sure the only thing broken is the amp. There are a lot of electronics in these cars better to be safe then break something. If you want to save on cost, I would recommend you buying the amp yourself and getting an indy to install it for you.
