W204 Rear Wiper Motor Not Working
The motor on my 2011 estate has stopped working. I have checked the correct fuse which seems fine. Can I assume that the motor has failed or is there anything else I should check.
I am quite willing to replace/strip the motor myself but cant seem to find how to remove the rear tailgate internal cover to have a look at this. Also any ideas on best supplier for a new one if required - I am assuming MB will charge a small fortune for an OEM part!
Many thanks
i have removed the rear door panal, it just pulls off. I have confirmed that the motor is not working using a meter, unfortunately i am unable to remove the wiper arm off the spindle as it is seized on. I have used penetrating oil and used a puller tool with no joy.
Watch this space!
