2008 C230 WIS documents needed. Flex disc and rear trans mount replacement.
Hello. I am wondering if anyone can please help me out by posting some WIS documents. I want to replace my rear transmission mount and flex discs.
WIS documents would be greatly appreciated.
2008 C230 4 Matic
VIN # - WDDGF85X18F147654
I am also hoping I don't need to pull the driveshaft to perform this service. From what I have gathered, I don't. I may just have to drop one side of my exhaust but I am hoping I can replace the flex discs without doing that.
2008 C230 4 Matic
Colin G (04-17-2018)
Thank you very much alecmascot.
If you can please post the flex disc document. My internet connection is pretty dodgy at best out in my garage and I like to print off and have on paper out there if I can. Will save me from running in and out of the house if I have to reference a video.
Thank you once again. That will help immensely.
I'd like to replace the support bearing, end bushings and rubber boot of the drive shaft but think I'll need special tools or pullers for that job. Figured if I am there replacing flex discs, I may as well replace the other bits also if I am able to.
