Anyone know where I can get these? its cable 1 from the pic below. Originally one side of my seat was moving while the other was not. After forum searches and talking to the dealer all I could find was "replace the seat". it ended up being a little plastic piece that holds the motor in place popped out taking the drive cable out of the hold and not moving that side of the seat. I fixed the issue with 2 zip ties, today after about a year I had the same issue. This time the same side of the seat is not moving, but the motor is in place. The drive cable is spinning, but that side of the seat is not moving. I'm going to try replacing the cable before taking the seat out and looking for something lodged in there. Anyone know where I can find these parts?
After reviewing pics and messing around with the side that works it looks like the actual hole the square drive cable goes into is stripped. I'm not sure if there is suppose to be another piece inside the hole that is square, but the drive cable actually slides in and basically spins freely. This happened recently so I'm not sure how the hole got stripped. I think my only option is replacing the entire track or hopefully using some lock tight and the drive cable will work.
