would 275/35/18 fit 18x9 rim
Old May 8, 2018 | 11:00 AM
Juice94102's Avatar
2009 C50 Sport
2009 c350 sport with amg wheels
Old May 8, 2018 | 11:10 AM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
I think 9 is really pushing it. 9.5s for sure tho.
Old May 8, 2018 | 12:48 PM
edgalang's Avatar
Factory ordered 2012 MB C350 w/Dynamic Handling Package
A 275/35ZR18 tire rim width range is = 9-11....so yes it would fit.
FYI, for future reference, you can go to tirerack.com.
Look for the tires you want, then go to the "SPECS" tab and look under the "Rim Width Range".
This range is the proper size wheel to mount the tire on.
On a side note...a "stretched" tire is one that is mounted on a wheel that is WIDER than the specified rim range, despite what others may say regarding the looks.
Example...I have 255/35-18 mounted on 18x9.5 on the rears. Some have said that this is a "slight stretch", however I'm well within the range since the appropriate size of the wheel should be between 8.5-10 (FYI...stock rears are 8.5).
