EBD,ABS AND ESC INOPERERATIVE MESSAGE
Old Sep 20, 2023 | 05:31 PM
bdobruna's Avatar
C300
Originally Posted by Odd Piggy
You must scan for trouble codes. ESC alone when turning could be a failing yaw rate sensor or steering angle sensor. But adding the cruise not working with the lights on may indicate phantom failures caused by some unrelated component.
I have scanned with Autel scanner and it doesn’t find anything
Old Sep 20, 2023 | 06:17 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
!!! This will make the diagnosis much more difficult.
I suspect something common to both problems. Yet it has to be unmonitored by a sensor. Maybe the front SAM or the pre-fuse block or intermittent connection to or from either.
Do you have a wiring diagram? I can’t get to sny of my manuals or WIS right now.
Old Sep 20, 2023 | 07:29 PM
JettaRed's Avatar
Veteran: Army
Which Autel scanner? Autel makes a bunch of stuff from really cheap generic OBD scanners to very expensive multi-vehicle scanners.
Anytime something like this comes up, I first ask how old the batteries are.
Old Dec 30, 2023 | 12:20 AM
DBowman35's Avatar
2011 Mercedes C300 Sport
I have the same car, got the same message today. Stopped, turned off car and restarted, seemed to drive fine for the next 4 hours on the highway. Gas pedal felt like it wasn't giving me full power when I was putting it down. What was the outcome for you?
Old Nov 8, 2025 | 02:33 PM
General Shelton's Avatar
W203 and w204
Originally Posted by Tonygh69
IN THE MORNING I DROVE THE CAR FROM MY GARAGE AND THE BRAKE EBD,ABS AND ESC INOPERATIVE MESSAGE POPED UP ALONG WITH A POWER STEERING INOP ALSO ANYONE HAS EXPERICED THIS ON A 2010 C350 ???
what was your solution
