M276 cam timing?
Old May 23, 2018 | 10:51 PM
Westsidegarage's Avatar
Clk63
M276 cam timing?
I’m an independent mechanic in Melbourne Australia, I spoke to Mercedes Australia and they won’t help. I don’t have access to wis. I’m working on a 2011 w204 with m276 engine, we’ve purchased all genuine parts from a dealership here, this thing had a rattle on start up my scanner revealed that the inlet camshaft adjusters bank 1 and 2 were faulty, I’ve stripped the engine down and marked everything but want to make sure I put it back together according to manufacturers specs. I am also doing the upper chain tensioner revision according to this eng no. Inc non return valves. What I need is tension settings and the setting of camshaft timing for this engine, you’re help would be greatly appreciated, thanks.
Old Mar 4, 2019 | 05:46 PM
Hardowar's Avatar
2012 ML350 2006 ML500
Hi I'm currently working on a 2012 ML 350 Gas. I was wondering if you found the cam timing marks. I couldn't find it. I was going to line up the gold teeth on the cams. Which this didn't work when put back together getting cam timing codes for bank 2 inlet and exhust. Your help would be greatly appreicated
Old Mar 5, 2019 | 06:47 AM
alecmascot's Avatar
W204 C220CDI 2011
Does This help ?
File Type: pdf
File Type: pdf
Old Nov 15, 2019 | 10:05 PM
f&m's Avatar
f&m
s 500
i saw this p d f and it did not help a lot. after we aligned the segments the timing is still of on the 276 engine. am i missing something ?
Old Dec 31, 2019 | 05:48 PM
Chevota's Avatar
E550 Coupe 2wd (2016)
The first .pdf made perfect sense to me. What is the problem? Are you saying you set it per the pictures yet it's still off? How exactly do you know it's still off?
Old Sep 20, 2020 | 08:01 PM
Skinnerjames's Avatar
2012 E350
Did you ever find a solution? I am having the same issue.
