My Alignment Report
Old Jul 3, 2018 | 03:36 PM
tapankd's Avatar
2014 C300 Sport 4Matic
My Alignment Report
So guys I just had new tires installed.. Opted for the Michellin Pilot Spot A/S 3+ Ultra Performance All Season Tires. So far its a night and day difference driving the car.
I had the Alignment done at the MB dealer and here is my report. Since I am no expert If someone could please take a look at it and let me know if everything is ok and if the dealer did a good job with the alignment.
Thanks in advance.
Old Jul 4, 2018 | 11:14 AM
superangrypenguin's Avatar
A car
To save some of us on eye strain, do you have a color version of this report? If not, you'll have to add up the upper and loser limits in the column Target Data, and then confirm that after correction values are within the upper/lower range. It's a PITA. If you have the color version, just make sure everything is green.
Ignore the ed values as they are manually entered.
If you still have some camber (and IIRC caster?) values and such exceeding the boundary, then you need to get the optional camber/caster kit installed, or just ignore it as it's no big deal.
