Changing Steering wheel c200 w204 sedsn
Old Jul 18, 2018 | 06:58 PM
Ideaken's Avatar
Mercedes c200 2.2 cdi
Hey guys, I'm kinda new here I just bought a mercedes c200 2012 and I'm looking to change my steering wheel into an avantgarde model. Should I be looking for a specific model and are there anything else I should be aware of when changing? E.g do I need to change the airbag as well or does it fit?
The car has automatic shifting
I posten pictures of my current steering wheel and one that I would be interested in.
Btw I live in Europe if that makes any difference
Thanks in advance!
Old Oct 4, 2018 | 06:35 AM
mmohammed's Avatar
C200 CDI W204 2011
I have the same steering wheel as you and going to do a steering wheel swap this weekend to the flat bottom AMG wheel. As long as the new steering wheel has a compatible airbag with it then it should be a straight swap. The airbag that you currently have will NOT fit on the flat bottom wheel. Also, the steering wheel buttons might not work after you have swapped so you might have to take the module out from under the airbag of your current wheel and swap it with the new one. Check out this thread for further details: https://mbworld.org/forums/c-class-w...heel-swap.html
Old Oct 8, 2018 | 05:26 AM
mmohammed's Avatar
C200 CDI W204 2011
Cool My steering wheel swap
Steering wheel swap done Here are the before and after pictures
Old Sep 17, 2019 | 02:48 PM
M~Factor's Avatar
2017 AMG GT, 2015 ML350, 2013 C300
