3548 - The on - board power supply voltage is too low
2009 MB C200 Kompressor sport 1.8 Petrol
2009 59 Mercedes C200 Kompressor Sport 1.8 Petrol.
Getting error code:
"3548 - The on - board power supply voltage is too low"
Any ideas?
I'm guessing to do with battery, but is it something that can be repaired, or is it best to replace the battery?
Any help/advice would be much appreciated.
Thanks in Advance
Getting error code:
Any ideas?
Thanks in Advance
why would you want to repair the battery? Batteries only last 2-3-4 years. Best to get it checked and if bad replace it....before you damage the electronics
what i meant is it to do with the battery or something else?
if its the battery then yeah definitely i’d replace it.
Cheers
Getting error code:
Any ideas?
Thanks in Advance
Getting error code:
Any ideas?
Thanks in Advance
I have the same car and the same issue, can you please help sharing your experience, what solved the problem
Replace the battery.
