Brake Fluid Flush Interval....
Old Aug 8, 2020 | 01:34 AM
Nicholi2007's Avatar
2015 C400 Tenorite Gray
Originally Posted by gamma300C
The only reason I have used a Dealer in the past (rarely) has been when I thought the ABS accumulator/system needed flushing too since you needed usually proprietary software to activate the system in the shop. Will you supply the correct DOT 4 LV fluid or rely on the mobile mechanic to know what your MB requires ?
I only rely on the mobile mechanic to do the work.
I'll call the dealer. Need to make sure it's correct and that the fluid is recent.
You don't want brake fluid that's been lying around for a long time.
