CANBus turn signal LED bulbs
Old Oct 4, 2018 | 05:46 PM
C300CA's Avatar
2011 C300 Sport, P1, MM, Wood, Heated FS, DIY rearview camera.
I online chatted with Superbright leds.com and here is what I got:
1. If a car has CANBus system, the LED bulb needs to be CANBut type;
2. with CANBus type turn signal LED bulb, I need to install it to find if the 6 Ohm resistor is still needed to stop rapid flashing.
My question is that my stock turn signal bulb is incandescent type that is not a CANBus bulb. Why can't I replace it with a non-CANBus LED with a 6 Ohm resistor?
Old Oct 4, 2018 | 07:02 PM
AZN Optics's Avatar
SPONSOR/MBworld Guru
Our 3457 super wedge LEDs for your signals are canbus with integrated flasher unit that will not trip error and sync flashing with your sidemirror signals. Simple plug and play with no need to splice in additional resistors.
http://www.aznoptics.com/index.php?m...products_id=62
Old Oct 13, 2018 | 10:52 PM
C300CA's Avatar
I got time to try a non CANBus LED, 7440A bought for my other car on my 2011 C. Took the rear left stock bulb out and connected this LED bulb in with no added 6 ohm resistor. To my surprise, there is no error message, turn signal flashes at normal speed.
I was expecting to see rapid flashing...
Old Oct 13, 2018 | 11:13 PM
AZN Optics's Avatar
Wait...2011 C class doesn't use 7440 bulb anywhere? Rear tail lights use 7507 bayonet bulbs for rear signals.
Old Oct 14, 2018 | 03:08 AM
C300CA's Avatar
7440 was bought for my 06 Honda Odyssey. I didn't get a chance to put it in with a 6 ohm resistor. Therefore, I tried it on 2011 C just to see what I could get. I used wires and clips to connect the LED to 7507 socket terminals.
Old Jul 13, 2020 | 08:07 PM
vitop's Avatar
2006 E320CDI, 2012 E350 Bluetec, 2013 E350 Bluetec
I have a 2006 E-Class and tried 6 or 7 Canbus turn signal bulbs but none worked for me. I would not get a Canbus error, but the bulb does not light up (never blinks). It just sits there.
I first tried AZN optics but they are out of these. He was very helpful and would not hesitate to buy from him if he gets stock back in.
In the meantime, this worked for me (FINALLY). https://www.ebay.com/itm/1157-Error-...72.m2749.l2649
Not the cheapest, but it works and they are nice and bright. I have no connection to these guys. Just trying to help in case someone else is having a problem getting bulbs to work in the front turn signal.
Old Oct 31, 2020 | 01:56 PM
Edmar1914's Avatar
ML 350 2010 Blue tech
I have a problem also on my (LEFT turn signal LED light of my ML350, 2010 INSTALLED in the folding mirror, when I notice it from the very beginning my LED light is getting really DIM and finally stop working, so what I thought is the light, I did replace the bulb assembly with a new one but still never work can you please help me out? do you have any information what could be it? Thank you in advance
