2012 C350 SAM/PreFuse
Sorry to skip the intro, desperate times afoot!
My car started to play up and after some extensive research I now believe it to be the pre fuse box /Sam modual.
After a good hour I have removed the prefuse box successfully and opened it up hoping to find a blown fuse, unfortunately this isn't the case, all fuses are in tact and passed the continuity test with my multi meter.
Do you advise I do anything else prior to reassemble? Inside the unit is a battery/coi lalong with a black box (sealed unit) how can I test these?
kind regards
James
kind regards
James
How did you disconnected the pyrofuse?
kind regards
James
kind regards
James
Parts # is 204 440 55 07
