Hissing sound from engine
I can't feel the air with my finger, and I'm pretty sure I reconnected everything from changing the air filter. The problem is I don't know where the hissing sounds are coming from, so I just want to ask where of the right side of the engine can leak air? I assume maybe it's a vacuum leak but I didn't even touch anything else in the engine bay, and the second reason might be the airfilter box are making the sound cause it's not sealed up?
I drove it for like 10 miles and everything was normal, no lose power, no rough idle and normal mpg.
Please help, thank you!
Was the hiss gone after 20 secs? My car also has that sound from a cold engine only, it goes away and then RPM drops to 600 ... to let me know that engine is warmed up
My experience is if the airbox is loose on its intake mount over MAF sensor, you get engine light, which goes away if you fix it.
This sounds like intake manifold vacuum, connections from below throttle body it must be to have this vacuum leak, so stuff that uses vacuum to operate I would search for and their connections to find the vacuum leak.
