c250 heater valve location
Old Nov 12, 2018 | 04:58 PM
Jaimemb's Avatar
2013 c250
Does anyone know where the heater valve is located on a 2013 c250. I don't have any heat and I've narrowed it down to the heater core being clogged or the heater valve being stuck.
Old Nov 12, 2018 | 05:26 PM
gamma300C's Avatar
2009 MB C300 Sport 4matic
https://www.pelicanparts.com/techart...eplacement.htm
Maybe this link will help some............
Old Nov 12, 2018 | 05:52 PM
Jaimemb's Avatar
2013 c250
Yeah I've seen that website before but it only works for c350 and GLK350 I'm guessing its a different set up because those engines are bigger then the 4 cylinder on the c250. I'm just so stuck on the location of it because nothing pops up for a c250 even part wise
Old Jan 6, 2019 | 07:10 PM
JimmyKudo's Avatar
C250
Hey Jamie, I have the same issue and I’m hoping you found the solution. Did you end up finding a guide on how to replace the heater control valve for W204 C250s?
My fan works fine and the heater usually works for the first couple minutes (which I presume is electrical heat), and sometimes it’ll actually heat at high RPM, but I believe the control valve is to blame. The engine temperatures seem fine so I don’t think it’s the engine thermostat.
Old Feb 6, 2019 | 04:11 PM
ieatz's Avatar
C250
Hi,
I just got the same problem with my C250 and dont want to pay $800 at the dealership...
Any luck finding a solution/part?
Old Oct 6, 2019 | 10:45 AM
Jaimemb's Avatar
2013 c250
Never figured it out the problem just went away :/ sorry for such a late response
