ESP light on and injector drift warning
Old Nov 13, 2018 | 03:37 PM
ElenaDemos's Avatar
w204.008 diesel
Hi guys,
My C220 CDI (W204-008) has the ESP light on and went into limp mode and the engine runs rough at idle. After diagnosis I get the following fault codes:
2071 injector drift cylinder 1 the lower limit value is reached
7201 One or more signals sent from control unit Engine Control module via the CAN bus is implausible
I can understand that in diesel cars, since the torque is controlled by the amount fuel injected, it sounds logical to get ESP fault because of a bad injector. Is this correct? Is the injector gone really bad or can I run an injector cleaner to see if it fixes the issue?
Thanks in advance
Old Dec 17, 2018 | 03:46 PM
maxflinn's Avatar
Mercedes
Hi I'm having very similar problems with my C220 Cdi Sport, and just got the same 2071 code also. I've started a thread if you'd like to keep an eye on it, as I shall this one.
Good luck!
Old Dec 18, 2018 | 07:00 AM
alecmascot's Avatar
W204 C220CDI 2011
This may provide some info on your issue :https://pmmonline.co.uk/technical/di...ng-procedures/
