Brake problem
What I want to know is, in sport mode it seems slightly better. BUT when it's in cruise control and I brake while dropping the cruise speed, it's really sharp.
Why aren't my brakes always good?
Is the brake fluid reservoir at the correct level ?
With the engine running if you pump the brake pedal does it go hard ?
With the engine stopped pump the brake pedal 10 times or so till it goes hard, then with your foot still on the brake start the engine. The vacuum servo should cause the pedal to drop further ?
Sports mode only affects the gearbox and Cruise Control should have no bearing.
if there was air surely even this wouldn't be so responsive. Putting it in sport seems to improve the braking.
