2013 with loose headlight
Old Dec 7, 2018 | 01:56 PM
jtharp's Avatar
2013 C250 Sport
Driving home the other night, some tire tread hit the front grill and popped the grill out of position. Easy enough fix. However, since then, my drivers side headlight is now loose and I cannot figure out how to tighten it. At first I thought I could tighten the star shaped bolt on the light, but that has not fixed the problem. What bolts/screws/nuts etc. should I look to tighten? Any help is greatly appreciated.
Old Dec 7, 2018 | 03:49 PM
gamma300C's Avatar
2009 MB C300 Sport 4matic
I would first suspect a broken headlight mount tab(s). Did the front take a pretty good wallop? Search YouTube or Google for the headlight retrofit videos to access the assembly and take a look see.
Old Dec 7, 2018 | 04:48 PM
MB Marko's Avatar
2012 C300 4Matic Sport Sedan
+1 I'd go this route first, the tabs are most likely the issue.
Old Dec 7, 2018 | 04:57 PM
jtharp's Avatar
2013 C250 Sport
Thank you. Yes, certainly took a good wallop and impact seems to have been near grill and headlight.
Old Dec 8, 2018 | 04:58 AM
krazzdav's Avatar
Veteran: Marine Corps
2017 GLA 250, 2011 C63 P31 (p30 w/ lsd) (in repair), 2005 C230 Sport Eurocharged, 2003 C320~sold
jtharp have to remove your bumper and you can use loctite 2-part plastic epoxy (or similar) to glue your broken tabs back (there are 3 mounting points) http://www.loctiteproducts.com/p/epx...tic-Bonder.htm
Old Dec 10, 2018 | 03:32 PM
jtharp's Avatar
2013 C250 Sport
Thank you everyone for the advice. I didn't realize that it involved removing the front bumper.
