Climate control
Old Jan 15, 2019 | 06:22 PM
triplmmm's Avatar
2020 c300
Climate control
My climate control defaults to a/c always. Is this normal? It's middle of winter in Ohio.
Also I had a engine warning light for a couple weeks. I did the same thing I always do. Nothing... It went away.
Old Jan 15, 2019 | 09:32 PM
MB Marko's Avatar
2012 C300 4Matic Sport Sedan
The ac button stays lit because that's humidity control in the winter.
Old Jan 16, 2019 | 05:43 AM
triplmmm's Avatar
2020 c300
Sound right
Makes sense.
Old Jan 17, 2019 | 12:54 AM
MB_FanAddict's Avatar
Exclamation
This is the automatic climate controls default setting when selecting "Auto" mode. If you don't want the A/C on, just press the A/C button to turn it off (the system will remain in full auto mode)! It is recommended run the A/C for a few minutes every month or so during the winter though. If you need to use the defroster, press the the defroster button again to revert back to the previous setting (likewise with the "A/C" and "Off" buttons).
There is no need to keep switching operating modes, fan speeds or even turn the system off. You may need to make slight temperature adjustments from time to time, but otherwise leave...it.....alone!
Old Jan 17, 2019 | 07:16 AM
triplmmm's Avatar
2020 c300
Thanks for the clear explanation. Makes sense.
