No sound
Thanks in advance.
First, reset the audio by pressing the CD eject button for 10+ second. You will see the audio system recycling.
Second, go back to the trunk and reach the Audio module. There unplug the fiber connection. You will see a red laser like light after removing the black clip. It has 2 orange thick wires and couple of other wires.
Reconnect. That's it.
Sound started again like a charm.
I chatted with Sirius through their online customer care. The rep was very helpful and sent a refresh to my radio based on my radio id as I do not have service.
30 minutes later and after 2 attempts at disconnecting the fiber optic connection to Sirius module the sound was back on.
It also tested fine after restarts.
But today morning it is dead again.
I have ordered a fiber loop so that I can bypass the Sirius module.
Anyone has any other ideas?
replaced the amp and it is all good now.
all u need to do is open your trunk.
remove two carpet trim clips, they are on up towards trunk lid very close to the trunk lid spring.
once u pop them out u can see a purple connector connecting to your amp.
this will be a quick check to confirm it’s location.
then go ahead order a new one.
i got mine from Chicago Mercedes for $660.
pull them out and u will see a module installed horizontally.
now u will need a fiber loop to test it.
if u can see Sirius preview on your command display then sirius is not your problem.
