Keyless Go not activated?
Old Mar 13, 2019 | 09:31 AM
Renlef's Avatar
2013 C250
Recently purchased a 2013 C250. I have checked the VIN and confirmed that 889 Keyless - Go is included. The door handles have the tell-tale indent, but I can’t seem to get keyless entry to work. Does it somehow need to be activated? I’ve changed key fob battery, checked for infrared signal, and whatever else Inhave seen here it elsewhere. I’m out of ideas on troubleshooting. Anyone know how to get this working?
Old Mar 14, 2019 | 08:29 AM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
You also need to have the keyless go start/stop button in the ignition where the key would go
Old Mar 14, 2019 | 12:34 PM
Renlef's Avatar
2013 C250
unfortunately I tried that just now and not only does it not work for keyless entry, the keyless start doesn’t work either. I’m completely flummoxed. Is there some sort of programming or other change that needs to happen?
Old Mar 15, 2019 | 03:44 AM
capt_paul's Avatar
Fuse perhaps....other than that, a dealer visit
Old Apr 1, 2019 | 04:04 PM
Renlef's Avatar
2013 C250
New wrinkle
I finally had the second key sent to me and Keyless Go works perfectly with that key. So now I have one key that both Keyless Go and Keyless Entry work fine and one key with no functionality at all.
Old Apr 2, 2019 | 07:06 PM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
Is it possible the no-functionality key is wrong one for the vehicle? Did it ever work in the past?
In my case, I changed both key batteries ... one works perfectly now, but the other does not unlock by touching the door handle. It does lock and unlock the doors by clicking the buttons. So who knows, maybe I should try another battery in that one .... or just leave it as my backup key and use the buttons. Seems a little finnicky.
BTW, I do not have the start/stop button in my ignition and its absence doesn't seem to affect any of the keyless-go functions.
Old Apr 7, 2019 | 01:03 PM
capt_paul's Avatar
The keyless go button would only affect starting or stopping the car...the entry lock unlock function should still work without the button installed, as long as you have your key in your pocket or on your person
