Oil Plug Cracked the Oil Pan..?
2008 Mercedes C300 4Matic Sport
Good afternoon everyone. I was changing my O2 sensors today when I noticed that my oil pan was cracked. The only problem is that I don't know what the oil pan is called; or what the part number would be..? I have researched it, but my drain plug seems to be separate from the oil pan. Can someone help me out and tell me what this part is called? Maybe even a part number..?
After researching, the only "oil pan" I can find is the small black one before the drain plugged
That would be your upper oil pan and let me tell you...... That will require removal of the front subframe and the front differential. Part #A2720100027
