Cost for 2013 C350 Timing Chain Replacement
The math is pretty grim. If I pay the dealership for this repair, I could be spending in a little over a year almost enough money to buy a new A class, especially after they knock off $1,000 for that Goodwill Offer! I can't in good conscience sell the car to a private buyer, but I'm not sure I'd lose much sleep if I could dump it on Mercedes-Benz. That's not an option, though. M-B wouldn't give me near what the Blue Book trade in value is because I paid them $200 to know what's wrong with it. Now every Mercedes-Benz dealership in America knows the problem with my car.
I asked what is the worst that can happen, and he said that he thinks this engine would not be totaled if the chain skipped a gear teeth. It would just shut down without further damage. Of course, at that point it really doesn't matter because either way it would be cheaper to put in a running engine. The only issue is the danger of the engine shutting down at 70 mph on the interstate. I suspect, though, that the chain would skip and engine shut down at start-up since that is when the chain is not under tension. My wife says do nothing and don't worry about it. Meanwhile, my son's 2005 Buick LaCross with 144,000 miles on it starts up and idles so quietly it's hard to tell it's running.
At this point I'm waiting to see what happens to jhanson25.
The vin is: WDD2183591A104361
Engine number: 276952 30 506204
Attached is the Service Bulletin for the engine.
1) Up to engine number 276 9xx 30 365996 install check valves and chain tensioners
2) From engine number 276 9xx 30 365997 up to engine number 276 9xx 30 406603 (February 2013) install check
valves only (optimized tensioners installed in this production range)
Engine number 276952 30 506204
The one in looking at has a higher number so I'm good.
The new problem is that I just found it that the engine light came on and that nothing had been done about it. I went to Mercedes to see its history, service and repair.
I asked the guy who is selling the Car, he said that he had driven the car with the handbrake one morning to work and that he felt something was wrong. After he took it to mercedes when the light came on and that they just turned the light off as it was no problem. He has been driving it for six months since then.
Could this be true? I'm not the best at understanding cars, but what does the handbrake have with the engine that will make the light turn on..?
Your engine number is 276957 30 423764
Wich according to the bulletin would have you covered. The one I'm looking it has a higher number than yours. But maybe I should be careful even though it says that the car is OK.
It sucks having to pay so much money for a repair that shouldn't have happened in the first place, especially so early on. On a Mercedes... I guess that guy in YouTube, Scotty Kilmer was right. Mercedes is a money pit machine 😂
I know it sucks but defiantly get other opinions I'm sure you can find someone to do it for way less then a mercedes dealer. There hourly rate is 50% or more that an independent shop. You can get it done for probably $2000 somewhere else. Don't jump the gun. Stay on top of maintenance afterwards oil change ever 8-10K transmission every 60,000 the car should last you forever!
Yeah, he hates BMW more, that's true. What are you going to do with your car? Did you fix it?
I really want this CLS, it pretty much had everything I want from a CLS. Recently sold my perfect Mercedes E klass AMG Coupe, it was very reliable. Owned it for three years without any problem at all. It was from 2012 so it had a few years on its back. That's why I'm so confused why Mercedes can make some of the best engines but also the worst.
Don't forget about the previous CLS and the M272 engine. From 2004 to 2008, a complete failure. I had the car for three months before the camshaft had to be replaced. I sold it and got the E class I told you about. I don't know, seems like a gamble..
my truck is a money pit chevy lol!! so far timing chain, fuel pump, ac compressor, fan clutch, water pump in 3 months of ownership costing $3000in parts and repairs( I paid 3k for it lol) so its tied right now with price paid for it and repairs done. no wonder i got a 10k truck for 3 K!! They quoted 15 hours on the timing chain i think they got it done in 13 and they gave me a discount on all parts 20% and 15% on labour. I had to talk to the mechanic to get the labour down they usually only do 10% but car guys love helping car guys, they said "it comes out of the mechanic pocket if its over 10%" it was an older guy doing the job he had no problem giving me and extra 5%. the rest I DIY save a ton of money and its easy to work on.
my benz- brake job, secondary air pump 2 times once under warranty once on my dime and i found the solution so it never happens again. in 5 years thats it other than tranny service(dealer does for $350) and oil changes I do myself. full brake job was $900 DIY secondary air pump was $300.oil changes I use mity vac $80 for oil for 2 changes and filters are $14. air filters are $40 for 2.
if you DIY these cars are a pleasure to own, if you go to a dealer your going to get raped on labour and parts.
Rock auto is a life saver! and for the jobs you can't do go to an independent. my indy charges $50 an hour I haven't gone to him in a while because i've been DIY'ing a lot. he only works on BMW,Volvo, some Mercedes.
A mechanic told me there is nothing to worry about, just some little thing that's loose and need to tighten up.
What do you guys think? Please help because I'm starting to get worried.
No engine light or anything. Could there be any more symptoms if it's the chain tensioner or something else serious?
Are you still driving around with your car?
I'm still driving the car and haven't had it repaired. The car's resale value is about $14,000. It's hard for me to justify spending $10,000 on it, especially when it's unclear how long it will go without the repair.
