How to reset SRS code?
Old May 31, 2019 | 05:15 AM
cabochad's Avatar
2008 C300 Sport
So, my 2008 C300 Sport had a seam split in the drivers seat. So I took it to an auto interior repair shop and then pulled the seat and fixed that problem. But since they disconnected (and reconnected) the wiring harness for the seat SRS, it now throws an SRS malfunction code and warning light. Do I seriously have to take my car to a dealer to get this cleared out? Note that it is the driver seat and not the passenger seat with the weight sensor in it.
TIA,
chad
Old May 31, 2019 | 02:00 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Dealer or buy an iCarsoft scanner for about the same price and clear it yourself, and have it for any future needs.
Battery is supposed to be unplugged when working with airbags.
Old May 31, 2019 | 10:15 PM
Life305's Avatar
2008 ML 550
is this the one you're talking about?
Old Jun 1, 2019 | 02:11 PM
cabochad's Avatar
2008 C300 Sport
The airbags were not worked with. The wiring harness UNDER the seat had to be unplugged to remove seat for repairs to commerce.
So is the only way to fix is to buy the damn reader or bend over at dealership?
Maybe it's finally time to start looking for that '69 Camaro....
chad
Old Jun 3, 2019 | 06:05 PM
soldr230's Avatar
2012 C250 coupe 2007 ML 350
Option 1 - Buy a scanner for $100 or less. (You can also read the engine/trans codes that may pop up in the future.)
Option 2 - Pay a local garage $60 to reset the computer.
Old Jun 4, 2019 | 01:44 PM
Adi-Benz's Avatar
The seat has weight sensors and whatnot that are safety related to the activation of airbags
Old Jun 17, 2020 | 06:36 PM
Sticktalk's Avatar
2013 c250
I also went thru this exact same scenario, and its annoying haha. I took my car into the dealer for the airbag recall very recently (After getting the leather on the cushion repaired, and was hoping they'd clear the code while performing the recall, but no luck) and they told me it threw 3 codes, which for the life of me cant figure out what they mean, so any help would be appreciated. Codes read as follows: b275013, b27e13, b009112 (also had my window regulator replaced on the driver door). So now I'm worried if theres anything wrong and the airbags wont deploy when needed?
