Electronic Starter Switch
Old Jun 12, 2019 | 08:14 PM
DOB33's Avatar
C Class 250cdi MY2013
Question Electronic Starter Switch
I have another problem that has happened twice so far. It is when I unlock the car and try to start the motor but when I turn the key it is like a black out. I called the road side service thinking that my reasonable new battery had failed. The mechanic connected the jumper leads and it made no difference so he checked the battery and I tried again with the same result. He then told me to get out of the car, lock it with the remote then unlock it with the remote, which I did and the car started as if nothing happened. I was then told it was a common fault with the car.
Luckily it has only happened twice in a short period of time and not since.
I called MB and they told me that they would fix the problem as a “goodwill gesture” (that conversation was recorded) and to take it to a dealer for a report which I did and the assistant service manager said that they would not recommend that it be repaired as I was advised (as a goodwill gesture).
Does anybody know if this is a common fault?
Old Jun 12, 2019 | 09:02 PM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
Most likely it is your steering lock that is failing. Eventually, it will stop working and then the car will no longer start. Did the dealership perform diagnostic? Did they say what’s wrong with it?
Old Jun 12, 2019 | 09:37 PM
DOB33's Avatar
Starter switch
Hi
thanks for your information but the dealer said that there were no faults recorded!
The assistant service manager said that it was probably the steering lock and that they have approximately two a month!
Old Jun 12, 2019 | 10:43 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
That's because there are no fault codes with the ESL (electric steering lock). It will leave you stranded.
Old Jun 12, 2019 | 11:50 PM
MBENZTECH's Avatar
When the electronic steering lock fails, there is a code stored in the electronic ignition switch. But if the systems starts to operate, the code is no longer present. You might want to get it fixed before it leaves stranded and you will have to spend extra on towing.
Old Jun 13, 2019 | 03:57 AM
DOB33's Avatar
Thank you all for the answers to my question I really do appreciate it and The car is booked into the dealer next Wednesday for assessment!
Will keep you informed with my progress!
