Staggered OEM Wheels - Okay to run a square tire setup on C300 4matic? 225/45R17?
running OEM AMG pkg 17x7.5 and 17x8.5 rims. Is it okay to run a square tire setup of 225/45R17 all around on a W204 4Matic C300?
any known issues? will it damage the drivetrain or AWD system?
Thanks in advance.
I went square on my car and run the same size tires and wheels all around. I think that's the best way to go, you could look for a pair of 7.5" wheels in the same style to run in back and then you'd be good all around. And you'll be able to rotate the tires and significantly increase their lifespan.
Better to spend a bit more on tires every once ina while than spend $6000 on a transmission.
In your particular case, as was mentioned, that is quite a stretch. It would work, but I don't know if you would like the way it looks visually though, but everyone is different. If it was me, I would just buy two new wheels for the rear that are the same as the front and be done with it. As Tom mentioned, makes it much easier to rotate the tires too. Even if you buy two new wheels you could sell the two rears you have now to help reduce the cost. Not that much money in the big scheme of things.
