2012 C300 sport sedan COMAND SYSTEM
Old Jul 18, 2019 | 05:24 PM
lion.pappa's Avatar
2012 C300
[SOLVED] 2012 C300 sport sedan COMAND SYSTEM
Hi all..wondering if anyone has some new solutions to freezing comand system. I have tried many options I found on this forum including removing fuse 6, 26, 28 for 15mins. Disconnect battery. Holding power/eject button. But none of them have worked.
I have now changed a new battery as the old one was well...getting old and start to show signs (brake hold not working). My situation happened after a day where I was in the parking lot waiting with music playing for about half 45mins; then the second day I was checking the socket size for the battery (removing battery for a friend so I just wanted to make sure I had the correct tools), but I did NOT remove the bolts, only test for the right size.
Then that afternoon, my comand system would go into a loop and keep restarting every 30secs or so, there would be a few second gap where I can still hit the radio/navi/disc buttons to change function but freeze after that (can still hear audio from radio, gps loaction is never correct). A shop I go to said I needed radio code, but I see no options to enter one. I went to MB services and asked for one, and was told that my car did not require radio codes anymore.
It is really frustrating....I thought it would be battery related as it happened after the signs of an old battery.
Does anyone have suggestions or I should just bring it in to MB services. Diagnostic is $250...I'd hate it to be just a simple fix that I haven't tried.
Thanks for any inputs (if any).
Old Jul 31, 2019 | 07:53 AM
henry666's Avatar
Mercedes Benz C280 2009
I have similar experience before in my 09 W204, my radio will hang while changing channel, then it will reboot itself after a few minutes.
It was battery drain due to bad light switch.
Then I did HU reset after that it back to normal.
I forgot exactly what I've done, but just simply go to setting or in engineer menu do the reset,
It will erase all settings and reset everything.
Just try it.
Old Jul 31, 2019 | 02:13 PM
lion.pappa's Avatar
2012 C300
Just try it.
Thanks for the reply and suggestion. What is a HU reset? The thing is I can't really "access" the menu/screen as it freezes within 10secs of restarting. I'll see what I can find on getting to engineering menu.
Old Aug 6, 2019 | 08:37 AM
henry666's Avatar
Try reset here in SYS menu.
If you unable access the menu due to system hang,
Try disconnect car battery for 10s then connect back again,
See if you have any luck...
If still fail then you will need Xentry to reset by computer.
Old Aug 6, 2019 | 02:03 PM
lion.pappa's Avatar
2012 C300
Hey Henry, thanks for the tips. I was able to navigate to engineering menu and did the reset (within like 10seconds before it froze lol), but it didnt work. Ill give this one a try again
Old Aug 6, 2019 | 04:59 PM
lion.pappa's Avatar
2012 C300
Wow, it worked! Things are back to normal now except for the Navi part which I don't use anyways. I can't believe all those battery unplug, fuse pulling, engineering reset did not work while this one did. Thanks so much, going to update thread title so others that might encounter the same thing in the future will give this a try.
Old Aug 14, 2019 | 08:19 AM
henry666's Avatar
I'm glad that worked for you.
I'm also curious power interruption can rude the settings that cause system hang like that.
