Clunking in front suspension on 2011 C300
I have changed the end links out with brand new Mercedes OEM units. I have also checked all control arm bushings, ball joints, sway bar bushings, etc and everything looks good. No leaks or cracks, etc.
The upper front control arm bushings don't show any cracks or signs of wear. They do have a tiny bit of play when twisting but I'm talking millimeters.
The only thing left that I can think of would be the strut assembly. Has anyone else had the same issue and it turned out to be the strut assembly? Any other thoughts?
Thanks!
I had the same mindset in replacing the easiest and cheapest part first with the end links. Didn't help my cause but at least they are now new.
My next thought is the struts/mounts since all bushings and ball joints appear to be fine.
Thats the arm that connects in the front correct? That’s the thrust arm, the one that goes straight in is the lower control arm. I would honestly say don’t bother with the unknown manufacturers for struts. They may be complete junk and not even fit quite right, they may even give you brand new mystery noises 🧐. I’d honestly get some Sachs or bilistein struts/OEM strut mounts and be confident they won’t be an issue. It’ll save u in the long run.
Yeah I would tend to agree. I honestly think the thrust arms are not the culprit. So maybe I'll take the money that would go to the thrust arms and put it into Bilstein struts and top mounts/bearings.
I have to remember this is only a daily driver, don't want to dump unnessesary money at it.
Heard nothing pushing nose up or down, dealer also did this, refuse theres something wrong with the new ones.
In the garage this vehicle is parked, I had a piece of 30x30mm wood mounted on cement so the door closed to it. So a week later I accidently discovered if I reverse fast out of the garage I can duplicate the clunk. I brought the dealer home, illustrate it to him, and they replaced both front struts again, problem gone forever. I did contact the strut company and they offered free of charge replacement even if it was not the shocks. For what its worth.
