Command center and ac shuts down when driving
Old Aug 20, 2019 | 06:35 PM
Futurebuyer's Avatar
2012 C300 4 matic
Hi guys so my 2012 c300 is messing up. When I’m driving I get a error on my command system screen “command system shutting off”. When this happens I lose turn signals my high beam indicator and e brake light on dash turn on. My ac shuts down and obviously the radio screen goes black. It turns back on after a few seconds, and still drives while off. It’s done this like 7 times in a 30 min drive. Anyone have this happen before? Is this a easy fix or am I about a to get a taste of my first costly repair.
thanks
Old Nov 22, 2023 | 02:51 PM
jasonK2k23's Avatar
2011 C350
Did you every figure out what the issue was? I am having the exact same problem now.
Old Jan 7, 2024 | 09:55 AM
MrDRE's Avatar
2011 C350 4matic
thanks
Hi. Did you ever get the radio/ac shutdown issue resolved? My 2011 C350 4matic is doing the same thing. Ive had to hit the side of the dashboard for it to work.
Old Jan 7, 2024 | 09:56 AM
MrDRE's Avatar
2011 C350 4matic
Did you find out what the issue was? I'm having the same problems with mine.
Old Jan 7, 2024 | 12:23 PM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
Most likely the command system is going out. You need to get it diagnosed properly by MB to know if that is the problem as can be a safety issue if it dissables your car's safety system.
Old Apr 19, 2024 | 08:18 PM
abbbb's Avatar
Mercedes Benz C300 2012
Did you ever get a solution for the command shutting down? I am having the same issue
I need a solution, My Mercedes Benz C300 model: 2012 keeps shutting down the command
Old Apr 19, 2024 | 08:20 PM
abbbb's Avatar
Help needed on my MB C300 2012 4matic
thanks
Did anyone get a solution to the command shutting down problems ? I am having the same issue
