green brown puddle at corner of car
Old Aug 21, 2019 | 11:31 PM
Bobby204's Avatar
2001 R129 SL500, '08-'20 W204 C350
so found this greenish brown clear liquid on the ground, its coming out of the driver side front bumper. Looking from top there's some stain near the antilock break thing. car seems to drive fine, coolant is full.
What could this be? AC leaking? Coolant hose? Washer fluid leaking?
Old Aug 24, 2019 | 04:21 PM
Bobby204's Avatar
Wiper fluid leaking
Mystery solved me thinks. This looks like wiper fluid, and its leaking from the driver side front bumper, where the reservoir is.
So looks like either wiper fluid pump, grommet, both?
Old Aug 25, 2019 | 12:41 AM
Bobby204's Avatar
Two pumps?
So are there two pumps? Looked online only see one listed.
Old Aug 25, 2019 | 06:03 PM
Bobby204's Avatar
Replacing the wiper pump
Local store had the part so replaced the seal and.pump.
1) rubber seal definitly suspect. Wet side is gummy and sticky. Also the outlet tube seem flimsy and crocket, might be cracked
2) the oem replacement parts went on really loose and leaked initially. Took it off noticed its gritty, so flushed the reservoir and cleaned opening. mew parts still went on lose, but does not leak anymore.
Old Aug 25, 2019 | 07:46 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
So problem solved?
