XENTRY/DAS C4
Old Sep 9, 2019 | 06:57 PM
JettaRed's Avatar
Veteran: Army
XENTRY/DAS C4
Does the C4 multiplexer not work with the W204? When I choose the C-Class, DAS only lists up to the W203. If I enter the VIN, it recognizes my car as 204.057, but does not show any controllers or anything. Do I need the C5 multiplexer? I'm using the latest 2019 version of DAS.
Old Sep 10, 2019 | 07:23 PM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
You must use XENTRY
Old Sep 11, 2019 | 09:48 AM
JettaRed's Avatar
Veteran: Army
I discovered that my problem was NOT with my C4 SDconnect, but rather not realizing that DAS only works on older cars (2011 and older, depending on the model). I have to use XENTRY with my 2014 C350 (W204), where DAS worked fine with my 2004 SL500 (R230). My question now is is there are Developer Mode with the XENTRY since it is not as apparent as with DAS?
