Easiest way to reset check engine light
Old Sep 23, 2019 | 01:09 AM
AmberLynnAndrew's Avatar
C250
Easiest way to reset/ erase check engine light on my 2013 c250? I have tried 2 different OBD scanners that said were capable of erasing the errors and both did not work. When I clicked the “delete”, it said loading, but would just freeze and not work. I have watched videos to do it by unplugging the battery, but don’t want to go thru the hassle of having to reset my radio if there’s an easier way. Thanks!
Old Sep 23, 2019 | 08:16 AM
JettaRed's Avatar
Veteran: Army
Stop messing around with general purpose OBD tools and spend $150 on an iCarsoft MB II. Search on Amazon.
Old Sep 24, 2019 | 07:02 PM
Ronin_Dax's Avatar
2013 C250 Sport
I've managed to reset mine with a Bluetooth odbii reader and Torque. I have to set the key to on without starting it, clear the code then switch the car off. Start a few minutes later and the codes are cleared
Old Sep 24, 2019 | 07:49 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Might be able to by disconnecting the battery for a couple hours, if it isn't a stored code
