secondary air system
Old Sep 25, 2019 | 08:22 AM
D3838374's Avatar
'10 glk350
I changed my pump, left and right check valves, fuse and relay. Hoses are all good. Pump still won't turn on at start up and engine light still on with the same code. what am I missing? all parts are mercedes brand
Old Sep 25, 2019 | 01:27 PM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
I've seen mention before of problems with a "secondary air pump" but couldn't find anything on this using search ... can someone explain a little further?
Old Sep 28, 2019 | 11:59 AM
RossP's Avatar
2008 C300 Sport
Why did you initially change the pump? Was it making the loud jet engine noise at start up or not running at all? Can you jump the pump from the battery to make sure the pump is not defective?
