AutoTalent | Renntech Ecu + Spoiler + Brake For Mercedes-benz W204 C320 2008-2014
Golan@AutoTalent.com
Renntech Performance Ecu Upgrade
Click HERE to order Performance Ecu!
RennTech has been at the forefront of ECU tuning since electronic engine management started to show up in vehicles during the mid 1980's. RennTech experience, countless hours of in house research, development and exhaustive testing ensure that our proprietary ECU upgrade offers incredible performance gains and rock solid daily driver reliability. The RennTech tuning module allows the user to change the performance level and gives the ability to set different performance levels running both higher or lower boost compared to delivered settings. This gives you power on demand or economy when you want with smooth torque delivery and performance throughout the entire powerband. This also allows the user to compensate for fuel quality and places of extreme climate or to adjust for higher octane fuels and the added performance of racing blends. RennTech tuning software for Mercedes offers significant gains in horsepower and torque across the vehicle's entire powerband. By modifying ignition timing and throttle mapping, optimizing air/ fuel ratios, increasing the engines rev limiter and modifying boost mapping for turbocharged vehicles, RennTech performance software unleashes your Mercedes true potential.
Features
Increasing performance from 230 HP and 389 lb/ft torque up to 253 HP and 464 lb/ft
Gains: +23HP & 75TQ
Increase driver reliability
Make installation simple
Increase performance
Ecu Upgradation
More horsepower
More torque
Stock Performance
230 HP / 389 LB-FT
Modified Performance
253 HP / 464 LB-FT
Renntech Carbon Fiber Front Strut Brace
Click HERE to order Front Strut Brace!
Click HERE to order Rear Strut Brace!
The Renntech Carbon Fiber Front and Rear Strut Tower Brace provides sharper handling by reducing flex under harder cornering conditions and helps to maintain the structural integrity of the towers over the life of the vehicle. Also the RennTech Front Strut Brace Stabilizer improves your vehicles responsiveness and high speed cornering capabilities. Especially in combination with our Turbo Upgrade, this feature improves the handling of your vehicle. This Front and Rear strut stabilizer improves your vehicles responsiveness and high speed cornering capabilities. Construction features include reinforced eight point mounting brackets and carbon fiber crossbar to minimize flexing between the vehicles strut towers.
Features
Improves the handling of your vehicle
Improves vehicles responsiveness
High speed cornering capabilities
High quality carbon fiber material
Eight point mounting brackets
Improved performance
Long-lasting reliability
Renntech Carbon Rear Mount Dtm Style Wing
Click HERE to order Rear Mount Dtm Style Wing!
The Renntech Carbon Fiber offering aggressive styling and functional performance. RennTech fully adjustable DTM style rear wing is designed to work in conjunction with our carbon fiber rear deck lid spoiler and improves rear down force and stability at higher speeds. The rear wing mounting piece and uprights are a single piece, manufactured from T-6061 aircraft grade aluminum and our full carbon fiber wing element includes adjustable struts as well as machined aluminum end plates with the RennTech logo. The rear wing mounting plate with wing uprights attaches to the trunk lid via the included trunk reinforcement mounting plate. This allows the wing to bolt behind the license plate and can easily be removed or installed within 10 minutes.
Features
High-quality carbon fiber material
Provide stability at higher speeds
Offering functional performance
Installed within 10 minutes
Offering aggressive styling
Improves rear down force
DTM style rear wing
Easily be removed
Lightweight
Renntech Performance Brake Package
Click HERE to order Performance Brake Package 1!
Click HERE to order Performance Brake Package 3!
RennTech understands that brakes are one of the most important components of any performance car. Big brake upgrades are some of the most capable systems available at any price. Designed specifically to complement and control the mass of high-performance Mercedes and AMG cars, RennTech's big brake packages deliver consistent, real-world performance and look great behind your performance wheels. RennTech basic brake upgrade uses braided steel lines (front and rear) and high-performance brake pads (front) to deliver more consistent brake pedal feel and reduce fade compared to stock. RennTech philosophy has always been to produce products without compromise.
Features
Deliver more consistent brake pedal feel
Reduce fade compared to stock
High-performance brake pads
High quality material used
Braided steel lines
Renntech Performance Transmission Upgrade
Click HERE to order Performance Transmission Upgrade!
RennTech transmission upgrade consists of a complete transmission disassembly and inspection as well as a mechanical upgrade to the transmission clutch packs. This allows us the ability to maximize the amount of friction materials contained within the transmission and in turn, the amount of power which can be transmitted through each forward gear. During final assembly the transmission also receives all new gaskets, seals, o-rings as well as a new transmission pan filter. RennTech 722.9 Seven speed Mercedes Transmissions increased engine performance it becomes necessary to further improve the drive line components, most importantly the transmission in order to ensure maximum power is transmitted to the drive wheels without transmission slippage. This can not be realized with software and only truly be accomplished by an internal mechanical upgrade to the transmission hardware. RennTech is the foremost authority on transmission upgrades and has done countless rebuild and upgrades for the most demanding dealers and clients for over 21 years. RennTech upgrade leads to improved shift response, shift timing, increased torque handling capabilities and greater drivability under extreme conditions without sacrificing around town comfort.
Features
Ability to maximize the amount of friction materials
Increased torque handling capabilities
Increased engine performance
Improved shift response
Greater drivability
Shift timing
Renntech Carbon Fiber Deck Lid Spoiler
Click HERE to order Deck Lid Spoiler!
RennTech is proud to introduce an all new rear decklid spoiler design for the Mercedes-Benz C-Class Sedan. This highly integrated pre-preg carbon fiber spoiler compliments the sophisticated and refined C-Class exterior design language. The spoiler is coated inside and out with an all new acrylic UV protection system. A second layer of UV protectant clear coating is also applied using traditional spray methods, in order to create a smooth and high gloss finish. RennTech decklid spoiler was designed, engineered and tested in-house as a fully functional aerodynamic exterior upgrade. The decklid spoiler offers a smooth transition of airflow. Its high quality prepreg carbon fiber construction is finished in a beautiful gloss top coat to ensure years of durability and stunning good looks.This decklid spoiler is a fully functional aerodynamic component as well as an aggressive exterior enhancemeni. The design is perfect as a stand alone component. RennTech carbon fiber rear decklid spoiler offers aggressive rear end styling and acts as a functional aerodynamic component to improve rear downforce and airflow across the rear of the vehicle at speed. Installation requires no modifications to the trunk lid or body work and installs using 3M double sided automotive adhesive strips. Its available in gloss or matte finish.
Features
Stunning good looks of vehicles
High quality meterials used
Looking more aggressive
Carbon Fiber meterials
Design is perfect
Simple to install
Glossy and Matte Finish
How to Place Your Order:
Phone Domestic: (855) 973-2757 X 104
Phone International: (310) 231-7800 X 104
E-mail: online@autotalent.com
Website: www.AutoTalent.com
Payment:
Attachment 439933
Installations:
Feel free to visit us at our facility in Los Angeles, CA.
We install everything we sell.
19143 S. Hamilton Ave
Gardena, CA 90248
Shipping:
All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible.
Hours of Operation:
Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only
