Dash lights on my C230?
Hi guys, so yesterday we had some snow in Toronto, and i was sliding around a little, i think i tripped an abs sensor or something. I need some help.
The first notice that came on the dash was "Power Steering Malfunction", than "Run Flat Indicator Inoperative", and i can remember the last one, "ABS, ESC..*****"
And the cruise control is also now not working. I hooked up a generic OBD scanner, and nothing comes up.
What do you guys think?
Any evidence of water infiltration on the front SAM box, driver's front engine compartment. Sometimes not evident from above look see but watered up at base. I have used compressed air to blow out that area.
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
If it's not that, then it will be a wheel speed sensor. They're somewhat cheap to replace, but try cleaning them first.
If you used a generic code reader and nothing showed up it could be because that reader could not read C codes, which if it is a wheel speed sensor it would show up as a C code.
