2011 c300 camshaft expansion plug part numbers?
2011 c300 4matic Sport
Does anyone with access to the catalog know the current correct part numbers for the 2 different sized expansion plugs on the rear of the engine for a 2011 w204 c300 (m272?) ? I have a nasty oil leak and suspecting that’s where it’s from but regardless I’ve put 80k miles on the car and never changed them. I usually buy parts from FCP but can’t seem to find these on their site. Also may be a stupid question but I don’t need to drain the oil before swapping these, correct?
![](https://staticssl.ibsrv.net/autocomm/EvoM/fcotmicon.gif)
You can buy them at Rock Auto for cheap:
https://www.rockauto.com/en/catalog/...haft+plug,5252
Also, check and see if your PCV valve is leaking:
https://www.rockauto.com/en/catalog/...on)+valve,5052
https://www.pelicanparts.com/techart...eplacement.htm
