M276 engine noise
Old Dec 4, 2019 | 06:02 AM
JettaRed's Avatar
Veteran: Army
M276 engine noise
I have a 2014 C350 Sport with about 70,000 miles. I’ve changed the spark plugs and have serviced the tranny, along with regular oil change at 5000 mile intervals using Mobil 1 0W-40. I’ve noticed a low knocking noise, somewhat irregular, from the rear of the engine on the driver’s side. Seems worse on startup, but doesn’t go away completely. Any ideas? Thanks.
Old Dec 4, 2019 | 06:54 AM
xsever's Avatar
2012 C300 4MATIC Sport
Most likely it's the common problem the M276 suffers from. Read the attached PDF and you'll understand what's happening and how to fix it.
File Type: pdf
Old Dec 4, 2019 | 08:03 AM
JettaRed's Avatar
Veteran: Army
Thanks, but no. That’s not it. This isn’t rattling and it’s not in the front of the engine. Plus my engine serial number isn’t in the range affected. This noise is more of a low frequency knocking and it doesn’t go away after starting. I’m beginning to think it’s the high pressure fuel pump.
Old Dec 4, 2019 | 12:16 PM
JettaRed's Avatar
Veteran: Army
Turned out to be my dipstick had worked it’s way out a couple of inches and I was hearing noise from the crankcase. Surprised I didn’t get an emissions code.
Old Dec 4, 2019 | 03:49 PM
a4ncar's Avatar
2012/2014 E350, 2017 E43, 2019 CLS53
Keep watching your dipstick on weekly basis and see it pops up again.
