No reverse or 2nd gear
Old Dec 7, 2019 | 06:11 AM
Fast n Furious's Avatar
W204 2.1D
Hi everyone.
Just joined the forum and need some advice please.
my 2011 W204 6 speed manual transmission suddenly developed a problem this morning.
I selected reverse ok and backed up. After that, it no longer selects reverse or 2nd gear. Very annoying.
Any ideas anyone?
Thanks.
Pete.
Old Dec 7, 2019 | 08:04 AM
Xzero's Avatar
2022 EQS 580 4MATIC Sedan, 2010 C-Class C350 4MATIC
You were obviously going too fast, too furiously.
j/k
If it worked then suddenly stopped, I’m wondering if the linkage broke? Does the shifter go into reverse the entire way but just doesn’t engage? Is the shift lock for reverse still working correctly?
Do you have a decent scanner that will bring up transmission codes?
Also, have you checked the fluid level lately? Should be easy on a manual transmission.
Old Dec 7, 2019 | 06:25 PM
W204 2.1D
Yeah... The stick no longer moves over to the reverse lock position and wont select 2nd even with the engine off.
1st selection is ok but not as good as I remember it. (wife's car) Other gears select ok. No weird noises, No leaks, so no reason to suspect an oil issue. It all worked just peachy yesterday!
I think it's unlikely to be a gearbox problem by the feel of it.
I strongly suspect its a linkage issue and hope to it get up on a ramp next week. (too cold and wet outside now for a kerbside job). There's probably a plastic part that has broken up and jammed.
Does anyone know if these linkage mech's are a serviceable item, or is it best to just get a 2nd hand mech and swap it out?
Regards,
Old Dec 7, 2019 | 06:49 PM
gamma300C's Avatar
2009 MB C300 Sport 4matic
Agree with linkage failure diagnosis as first spot to check. The clutch pedal assembly has a plastic pivot pin that can get wonky also.
Old Dec 11, 2019 | 02:49 PM
W204 2.1D
I've learned that there are a variety of different part numbers for these 6 speed 204 gear shift mech's and negligible info indicating they have any weaknesses. Apparently though, it's important to replace with the exact part number.
I managed to squeeze the right part number from my local dealership and bought a second had one on-line for £75.00. Less painful than the £450+ for a new one.
Hopefully it will all be done by next week.
Old Jan 15, 2020 | 08:56 PM
W204 2.1D
Well it took me a month to get it sorted but sorted it is now.
Had to send the car to a gearbox specialist in west Yorkshire to have it done.
Basically, there is a spring that breaks on the selector mechanism inside the gearbox.
Mercedes apparently supply a kit of selector parts to fix this known reverse select issue that is getting more common now that a lot of these cars have seen over 150k miles.
Back pocket is now £800 lighter.
Old Jan 15, 2020 | 08:58 PM
gamma300C's Avatar
Thanks for the follow up...
Old Apr 23, 2021 | 07:42 AM
Ik Dhariwal's Avatar
C200 cdi
Same problem 84k and the same issue ffs
Bit of a long shot, but would know what part number it was and did the selector kit fix your 2nd gear issue or was that just for reverse.
Ik
Old Apr 23, 2021 | 11:21 AM
W204 2.1D
Ik
Sorry. I dont know what the part numbers are. All I remember the the gearbox specialists saying is that it needed a spring that had broken internally within the gearbox. Apparently, it's a known issue and merc supply a selector kit with the new spring to fix it.
It's been perfect since it was done.
Pete.
Old Dec 16, 2021 | 05:22 AM
Nomisg1's Avatar
C220 cdi
Pete.
hi did u get this sorted
Old Nov 6, 2023 | 06:02 PM
dl3325's Avatar
mercedes 220d
Hi - do you have the name of the garage that completed the work?
Old Nov 15, 2023 | 05:15 PM
W204 2.1D
It was nearly 4 years ago now so i dont actually remember the name of the garage or the street it was on but it was a known specialist on the outskirts of Huddersfield. They did a good job though cos that car is still on the road.
Maybe a bit of googling around for gearbox repair specialists in the huddersfield area may answer your question?
Sorry i cant be of further help. Good luck to you.
Old Nov 16, 2023 | 08:43 AM
JettaRed's Avatar
Veteran: Army
Please translate "gearbox" for us on the western Atlantic. Is that the same as transmission over here, or is it in the gear shifter assembly? There's not many manual transmission Mercedes here.
Old Nov 16, 2023 | 09:14 AM
W204 2.1D
Its a "gearbox" on my side of the pond and "Transmission" on your side........ Gear stick mech over here and shifter mech over there.
Old Nov 16, 2023 | 12:13 PM
JettaRed's Avatar
Veteran: Army
Thanks so much! I now feel more "international".
