Transmission fluid top up
I got my diagnostic tool. It shows 2 error codes. P0101 (mass or volume air flow A circuit range /performance.
P0473 (exhaust pressure sensor A circuit high.
I cleared them and its no longer in limp mode but it is revving up & down when at a constant throttle ...Only at fairly high rpm but not when driven gently. Any ideas.
I eventually took the car to Mercedes-Benz. They quoted me R19000, saying I needed to replace a turbo seal, EGR valve & exhaust pressure sensor. I ended up replacing the exhaust seal & cleaned the EGR valve but that made no difference so I replaced the exhaust pressure sensor & that solved the problem. It cost me 10 x less than Merc quoted ie R1900.
