I have a 2012 C63 with the P30 pack. I have just done the rear rotors, replaced them with Brembo 09.A326.11 which are the correct match however i can't tell what style of pad i should be using?
The ones I got are Brembo P50110 but the ones I removed are P50113 which are a little different, the P50110 pads fit and everything lines up as it should but the shim plate doesn't connect as the notches on the pad are different.
These are the P50113's which are on my car at the moment (need replacing)
And these are the ones i bought, P50110 based on what the Brembo site said
Can anyone tell me which ones are the correct ones for my car? It is possible that someone put the wrong pads on it last time...
