Problems removing blower motor
Everything was going well; I got the footwell underpanel removed, unhooked all the wires, and then it came time to pull out the motor
For the life of me, I can’t get this thing out. There’s no play or anything. It’s practically jammed in there. I’ve pulled down on the blower’s tab and attempted to rotate and pull out the motor unit, but it won’t budge. Am I missing something? I’m not seeing any sort of bolt or screw holding it in place. Do I need to remove the glovebox? I’m basing my removal method off the W204 technical articles from Pelican Parts, which doesn’t mention having to remove the glovebox; however, I believe their removal article was performed on a 2008 model. Any insight would be much appreciated.
Pull down the tab and at the same time rotate the opposite direction of the arrow. This would be clockwise if you are lying down and looking up at the motor. You need to make sure the wiring tabs are out of the way.
Don't pull down until you have completely rotated (arrow on blower matches up with arrow on housing).
For 2009 no need to remove the glove box.
I’ll be riding around for a few days with the footwell panel removed. That is a tight space under there.
In the end, the repair will cost me $303, just for the cost of the regulator and blower motor. Not sure how much my local MB dealer wanted, didn’t even bother to inquire, but according to repairpal.com, it could’ve ran me 500-600 dollars and that’s probably from an Indy shop.
Why'd you replace the resistor?
You're probably right about the transit damage now that I think of it.
I replaced the regulator just because, essentially. I'm under there; might as well do it along with the cabin filter. The regulator and the motor are the originals that came with the car in 2009; they had a great run I'd say.
