Help: Will Vorsteiner carbon fiber side skirts fit my car
Old Jan 18, 2020 | 08:14 PM
Callum Forbes's Avatar
Mercedes Benz C250 AMG
Hi. I’ve got a 2012 w204 c class AMG coupe and was wondering if the C63 vorsteiner carbon fiber side skirts would fit my car? I really like the look of them but can’t seem to find any that aren’t advertised as C63 vorsteiner side skirts. Any help would be really appreciated. The side skirts I’m on about are pictured below
Old Jan 19, 2020 | 01:05 AM
curt.r's Avatar
2013 P31 C63 Sedan
Unfortunately they will not. Being that it is an extension of the C63 side skirt, they will not fit your car. That being said, you'd need to find a pair of C63 side skirts to put on your car, then these will fit no problem.
Old Jan 19, 2020 | 02:17 PM
Thanks for getting back to me bud. Just to clarify, do you mean I would need to get c63 rocker panels in order to fit the vorsteiner skirts to my car? If so, do you know if the dimensions of the c63 rocker panels are the same as the w204 c class ones?
Old Jan 20, 2020 | 01:46 AM
curt.r's Avatar
2013 P31 C63 Sedan
No problem. Yes that's correct, you will need the C63 coupe side skirts to attach the vorsteiner skirts. The rocker panel is the same length on the non-AMG w204 and AMG. The reason you need the C63 coupe side skirts is because of the design difference. If you look at the side skirt, the non-AMG has a different shape than the AMG.
Non-AMG:
AMG:
Old Jan 21, 2020 | 07:54 PM
[QUOTE=curt.r;7958121]No problem. Yes that's correct, you will need the C63 coupe side skirts to attach the vorsteiner skirts. The rocker panel is the same length on the non-AMG w204 and AMG. The reason you need the C63 coupe side skirts is because of the design difference. If you look at the side skirt, the non-AMG has a different shape than the AMG.
Wow thanks mate, that actually makes complete sense! Appreciate the info
