Transmission Range Sensor Circuit
Thanks,
Rob g
Thanks for the reply.
Got this at WalMart....can you clear the code and, if so, it comes back?
I have the same error code on my 2012.... What is weird after I clear the code, it will not come back on unless I re-start the car within an hour of turning it off. Meaning I can drive to work, let it sit for hours, drive home and no code. However I can start with no code, run to the store go to start the car back up and get the code to trigger. Very weird.
Anyone know where I can find the part number for a 2012 C250 ?
My 2011 C180 CGI recently popped up a CEL, and upon diagnosis, dealer puled out codes P0705 (Selection range sensor A has an electrical fault) and P0606 (Component Y3/8N4 is faulty) and recommended replacing the "electrohydraulic transmission control unit". My car only has 46k kms on the clock and has been maintained religiously by the dealership.
The car drives fine, no jerks and no LIMP mode, and I am not really convinced on the need to replace the whole control unit, given my low mileage. Hoping its probably just a minor glitch somewhere. Regarding the shifter assembly circuit board as mentioned by Gamma300C - I understand there have been a few posts mentioning this in the W203 forums, and I was told the W204 with 722.9 boxes don't have such component - would you be able to confirm this?
Regards,
Mo420
Regards,
Mo420
Regards,
Mo420
https://circuitboardmedics.com/blog/...view-solution/
For benefit of others, the other thread can be found here: https://mbworld.org/forums/c-class-w...ml#post8029794
Regards,
Mo420
I have the very same issue as you. Exact same two codes. No problems driving. Just wondering what your specific fix was please?
Thanks!
I just recently purchased a 2007 W203 with a 722.6. While during the first test drive, the car was stuck in gear and was in limp home mode. Unable to go from D to P only D to N unless the engine was shut off. I was assuming a conductor plate. (Came back later with the person having the car idle for a while to charge up the battery.) That test drive was perfect.
After purchasing the vehicle, as soon as I left the location of purchase... Stuck in gear limp home mode. (Same story, can't go into P with the engine running)
Finally after pulling off shortly to fill up, drove fine.
Mile down the road, limp mode again.
Pulled over and tried 3 times cycling the ignition off and on to get the D back in the display.
No avail.
Pulled out my OBD reader and saw it was not a speed sensor like I was expecting but P0705.
After parking it and trying again, everything seemed fine. Just stuck with a CEL that went away after a day of driving.
Battery is testing amazing under load. (Had to test to be sure)
Have the issue again. It's not the conductor plate. Is the shift selection delphi control part.
I made sure my TCM was bone dry. With the issues I'm seeing, it's definitely the sensor having issues.
Crossing fingers my reflow of solder will be the solution. That and cleaning the sensors on the board.
I may make a video, though all credit will go the the creator in Indonesia.
Removing the component, I broke a tab that slots into the shift rod.
I glued it back in place... As for the solder re-flow. I was using my fine tip and I believe I knicked a top edge of one of the sensors while reflowing a pad.
Now, is reading P and R but definitely messed up N and D.
If you attempt this component level fix, definitely need a finer tip than what I used and a microscope setup.
Random location given to the based off speed of gear shift.
Annoying mess up on my part. Removing the assembly inside the shifter without damage is my bad. It's a one way clip.
To remove it safely, you must remove the entire gear selector shaft.
