Number Pad Stops Working
Hello everyone,
I am wondering if some of you share the same problem I have where the COMAND number pad/buttons stop working sometimes. Pressing the buttons does nothing in any of the modes I use (Radio, iPod, SD Card, etc.).
Turning OFF and ON COMAND does not solve the problem. Holding the power button until the system resets does nothing neither. The problem eventually goes away when I turn OFF the car and then use it again.
From my research, I found one similar encounter here with a C63 but without a solution neither: https://mbworld.org/forums/c63-amg-w...sn-t-work.html
Could this be fixed with a software/firmware update of the unit? Any help would be appreciated.
Thanks.
Thanks.
My volume knob Would stop working and I could only change the setting with steering wheel controls. What I ended up doing was taking the knob off and blowing air into the area it rest it. Hasn’t stopped working since. Not sure if this could help you in some way. It’s free and worth a shot.
Last night a similar thing happened where the middle and right rows of numbers emulated the ‘2’ or ‘5’.. meaning if I pressed the 9 it would do the same thing as if you pressed the 2.. I’m talking radio presets here. The only buttons that worked correctly were the 1,4 and 7..(I never used the *)
But this morning all the numbers worked fine. 🤔
I can still achieve the desired results when using the COMAND wheel so I’m not too concerned, unless more things start acting weird as well.
Sub’d for possible answer as well.
I'm planning on asking my mechanic to do a software update for the control unit next time I take the car for an oil change.
I might also ask him to update to the 2013-2014 COMAND user interface with black and red.
