Engine stall when selecting R
Old Mar 27, 2020 | 04:55 PM
Alinos007's Avatar
C250cdi
Cool Engine stall when selecting R
Hello
This morning I start my engine and 2 minutes later I go to R to leave the garage and the engine stops
After I restart and leave the garage without problem
Before, and I already posted on this problem, when I went to D after cold start I felt a shock which would make the car jump forward if I did not have my foot on the brake
This morning the engine preferred to stall?
After all is normal and no engine light
The box (722.6) was flushed 30,000 km ago. No residue
Its a C250cdi from 2010
WDD2040031A419796
I had the same problem on my c220cdi in early 2011 722.6 box too and the gearbox ended up breaking (skating)
Do you have an idea ?
thank you so much
Old Mar 30, 2020 | 05:29 AM
NZ-Merc's Avatar
W204 C200, BMW E30 M3, 1980Gt Mini, Toyota Corona, KTM 200 EXC.
Almost sounds like there is a problem of the torque converter lock up clutch is engaged at idle or some other fault inside of the converter.
